(** {1 MPRI lecture 2-36-1 "Proof of Programs"} *) (** {2 Binary search, with exceptions} *) use int.Int use int.ComputerDivision use array.Array predicate sorted (a: array int) = forall i j:int. 0 <= i <= j < length a -> a[i] <= a[j] exception Break int exception Not_found val a : array int let binary_search (v: int) requires { sorted a } ensures { 0 <= result < a.length /\ a[result] = v } raises { Not_found -> forall i:int. 0 <= i < a.length -> a[i] <> v } = try let ref l = 0 in let ref u = a.length - 1 in while l <= u do invariant { 0 <= l } invariant { u < a.length } invariant { forall j. 0 <= j < l -> a[j] < v } invariant { forall j. u < j < a.length -> a[j] > v } variant { u - l } let m = div (u + l) 2 in if a[m] < v then l <- m+1 else if a[m] > v then u <- m-1 else raise (Break m) done; raise Not_found with Break i -> i end (* Local Variables: compile-command: "why3 ide bin_search_exc.mlw" End: *)
