(** {1 MPRI lecture 2-36-1 "Proof of Programs"} *) (** {2 Binary Search in an Array *) use int.Int use int.ComputerDivision use array.Array predicate sorted (a: array int) = forall i j:int. 0 <= i <= j < a.length -> a[i] <= a[j] let binary_search (a : array int) (v: int) requires { sorted a } ensures { -1 <= result < a.length } ensures { result >= 0 -> a[result] = v } ensures { result = -1 -> forall k. 0 <= k < a.length -> a[k] <> v } = let ref l = 0 in let ref u = a.length - 1 in let ref res = -1 in while res < 0 && l <= u do invariant { 0 <= l } invariant { u < a.length } invariant { -1 <= res < a.length } invariant { res >= 0 -> a[res] = v } invariant { res = -1 -> forall k. 0 <= k < l \/ u < k < a.length -> a[k] <> v } variant { u - l } let m = div (u + l) 2 in if a[m] < v then l <- m+1 else if a[m] > v then u <- m-1 else (res <- m ; l <- m+1) done; res (* Local Variables: compile-command: "why3 ide bin_search.mlw" End: *)
