(** {1 MPRI lecture 2-36-1 "Proof of Programs"} *) (** {2 Factorial: recursive specification, iterative implementation} *) use int.Int let rec function fact (n:int) : int requires { n >= 0 } variant { n } = if n=0 then 1 else n * fact (n-1) let fact_imp (x:int) : int requires { x >= 0 } ensures { result = fact x } = let ref y = 0 in let ref res = 1 in while y < x do invariant { 0 <= y <= x } invariant { res = fact y } variant { x - y } y <- y + 1; res <- res * y done; res (* Local Variables: compile-command: "why3 ide fact_sol.mlw" End: *)
