(* Inefficient sum *) use int.Int val ref a : int val ref b : int val ref x : int val ref y : int let sum () requires { b >= 0 } ensures { x = a + b } diverges (** we are not yet attempting to prove termination *) = x <- a; y <- b; while y > 0 do invariant { y >= 0 } invariant { x + y = a + b } x <- x + 1; y <- y - 1 done end (* Local Variables: compile-command: "why3 ide imp_sum_sol.mlw" End: *)
