(** {1 MPRI lecture 2-36-1 "Proof of Programs"} *) (** {2 Linear Search in an Array *) use int.Int use array.Array let linear_search (a: array int) (v:int) : int ensures { -1 <= result < a.length } ensures { result >= 0 -> a[result] = v } ensures { result = -1 -> forall k. 0 <= k < a.length -> a[k] <> v } = let ref i = 0 in let ref res = -1 in while i < a.length do invariant { i >= 0 } invariant { -1 <= res < a.length } invariant { res >= 0 -> a[res] = v } invariant { res = -1 -> forall k. 0 <= k < i -> a[k] <> v } variant { a.length - i } let t = a[i] in if t = v then res <- i; i <- i + 1 done; res (* Local Variables: compile-command: "why3 ide lin_search_sol.mlw" End: *)
