(** {1 MPRI lecture 2-36-1 "Proof of Programs"} *) (** {2 In-place Linked List Reversal} *) theory ListReverse use export int.Int use export list.List use export list.HdTlNoOpt function append (l1:list 'a) (l2:list 'a) : list 'a = match l1 with | Nil -> l2 | Cons x l -> Cons x (append l l2) end let rec lemma append_nil (l:list 'a) variant { l } ensures { append l Nil = l } = match l with | Nil -> () | Cons _ t -> append_nil t end let rec lemma append_assoc (l1 l2 l3:list 'a) variant { l1 } ensures { append (append l1 l2) l3 = append l1 (append l2 l3) } = match l1 with | Nil -> () | Cons _ t -> append_assoc t l2 l3 end function rev (l:list 'a) : list 'a = match l with | Nil -> Nil | Cons x r -> append (rev r) (Cons x Nil) end predicate mem (x:'a) (l:list 'a) = match l with | Nil -> false | Cons y r -> x=y \/ mem x r end predicate disjoint (l1:list 'a) (l2:list 'a) = forall x:'a. not (mem x l1 /\ mem x l2) predicate no_repet (l:list 'a) = match l with | Nil -> true | Cons x r -> not (mem x r) /\ no_repet r end end module InPlaceRev use ListReverse type loc val eq_loc (l1 l2:loc) : bool ensures { result <-> l1=l2 } val constant null:loc function store (f:'a->'b) (i:'a) (v:'b) : 'a -> 'b = fun j -> if i=j then v else f j val acc (ref field: loc -> 'a) (l:loc) : 'a requires { l <> null } reads { field } ensures { result = field l } val upd (ref field: loc -> 'a) (l:loc) (v:'a) : unit requires { l <> null } writes { field } ensures { field = store (old field) l v } predicate list_seg (p:loc) (next: loc -> loc) (l:list loc) (q:loc) = match l with | Nil -> p=q | Cons h t -> p <> null /\ h=p /\ list_seg (next p) next t q end (* lemma empty_list : forall next: loc -> loc, q:loc, l: list loc. list_seg null next l q -> l = Nil lemma list_seg_no_repet: forall next: loc -> loc, p: loc, pM:list loc. list_seg p next pM null -> no_repet pM lemma list_seg_frame: forall next1 next2: loc -> loc, p q v: loc, pM:list loc. list_seg p next1 pM null /\ next2 = store next1 q v /\ not (mem q pM) -> list_seg p next2 pM null *) val ref next : loc -> loc let reverse (l:loc) (ghost lM:list loc) : loc requires { list_seg l next lM null } ensures { list_seg result next (rev lM) null } = let ref p = l in let ref r = null in while not (eq_loc p null) do variant { 0 } let n = acc next p in upd next p r; r <- p; p <- n; done; r end (* Local Variables: compile-command: "why3 ide linked_list_rev.mlw" End: *)
