MPRI
This page presents teaching material for Course 2-36-1 "Proof of Program" of the MPRI 2021-2022.
Organisation
  • Time: Tuesday, 16:15 to 19:15.
  • First course: December 7th.
  • Project description: January 14th
  • Project due: February 24th
  • Exam: March 8th, 16h15-19h15, room 1004
Tools
Example programs for some lectures will be using the verification environment Why3. There is an on-line version of Why3 that can be used to replay the simplest examples. However, for more complex examples and for the project that require several provers, it is necessary to install Why3 and the automated provers.
You may find detailed instructions in this installation procedure.
Exam
The text of the exam, and a version including the solutions.
The project was provided on January 14th.
The project consists of the verification of algorithms using dynamic programming. A skeleton file is provided in a zip archive
To install Why3 and the automated provers, follow the installation procedure.
Lectures
Slides and examples will be posted here.
Part 1: Program verification using Hoare Logic, lectured by Claude Marché.
Part 2: Separation Logic and representation predicates, lectured by Jean-Marie Madiot. Ask Jean-Marie by email or during the class if you'd like printable versions. Please note that the slides are subject to occasional change.
Past Years
You may have a look at the exam of 2014. Once you have solved all exercises (and not before!), you may check some of the solutions.
You may have a look at the exam of 2015. Once you have solved all exercises (and not before!), you may check some of the solutions.
You may have a look at the exam of 2016. Once you have solved all exercises (and not before!), you may check some of the solutions.
You may have a look at the exam of 2017. Once you have solved all exercises (and not before!), you may check some of the solutions.
You may have a look at the exam of 2019-2020. Once you have solved all exercises (and not before!), you may check some of the solutions.
You may have a look at the exam of 2020-2021. Once you have solved all exercises (and not before!), you may check some of the solutions.
Page generated on 2023/3/11
