(** {1 MPRI lecture 2-36-1 "Proof of Programs"} *) (** {2 Binary Search in an Array *) use int.Int use int.ComputerDivision use array.Array predicate sorted (a: array int) = forall i j:int. 0 <= i <= j < a.length -> a[i] <= a[j] predicate _TO_BE_COMPLETED constant _VARIANT_TO_BE_COMPLETED:int (* replace all occurrences of _TO_BE_COMPLETED below *) let binary_search (a : array int) (v: int) requires { _TO_BE_COMPLETED } ensures { _TO_BE_COMPLETED } = let ref l = 0 in let ref u = a.length - 1 in let ref res = -1 in while res < 0 && l <= u do invariant { _TO_BE_COMPLETED } variant { _VARIANT_TO_BE_COMPLETED } let m = div (u + l) 2 in if a[m] < v then l <- m+1 else if a[m] > v then u <- m-1 else res <- m done; res (* Local Variables: compile-command: "why3 ide bin_search.mlw" End: *)
