(** {1 MPRI lecture 2-36-1 "Proof of Programs"} *) (** {2 Linear Search in an Array, with an exception *) use int.Int use array.Array predicate _TO_BE_COMPLETED constant _VARIANT_TO_BE_COMPLETED:int (* replace all occurrences of _TO_BE_COMPLETED below *) exception Exit let linear_search (a:array int) (v:int) ensures { -1 <= result < a.length } ensures { result >= 0 -> a[result] = v } ensures { result = -1 -> forall j:int. 0 <= j < a.length -> a[j] <> v } = let ref i = 0 in try while i < a.length do invariant { 0 <= i <= a.length } invariant { forall j. 0 <= j < i -> a[j] <> v } variant { a.length -i } if a[i] = v then raise Exit; i <- i + 1 done; -1 with Exit -> i end exception ExitWith int let linear_search_with_for (a:array int) (v:int) ensures { -1 <= result < a.length } ensures { result >= 0 -> a[result] = v } ensures { result = -1 -> forall j:int. 0 <= j < a.length -> a[j] <> v } = try for i = 0 to a.length - 1 do invariant { _TO_BE_COMPLETED } if a[i] = v then raise (ExitWith i) done; -1 with ExitWith i -> i end (* Local Variables: compile-command: "why3 ide lin_search_exc_sol.mlw" End: *)
