(** {1 MPRI lecture 2-36-1 "Proof of Programs"} *) (** {2 Modeling of 32-bits machine integers} *) module Int32 use export int.Int use export int.ComputerDivision function min_int: int = -2147483648 function max_int: int = 2147483647 predicate in_int32 (n:int) = min_int <= n <= max_int type int32 val function of_int32 int32 : int axiom bounded: forall x:int32. in_int32 (of_int32 x) val cst32 (x:int): int32 requires { in_int32 x } ensures { of_int32 result = x } val add32 (x y:int32): int32 requires { in_int32 (of_int32 x + of_int32 y) } ensures { of_int32 result = of_int32 x + of_int32 y } val sub32 (x y:int32): int32 requires { in_int32 (of_int32 x - of_int32 y) } ensures { of_int32 result = of_int32 x - of_int32 y } val mul32 (x y:int32): int32 requires { in_int32 (of_int32 x * of_int32 y) } ensures { of_int32 result = of_int32 x * of_int32 y } val div32 (x y:int32): int32 requires { of_int32 y <> 0 } requires { in_int32 (div (of_int32 x) (of_int32 y)) } ensures { of_int32 result = div (of_int32 x) (of_int32 y) } end module BinarySearch use int.Int use Int32 use array.Array predicate sorted (a: array int) = forall i j:int. 0 <= i <= j < length a -> a[i] <= a[j] exception Break int32 exception Not_found val a:array int let binary_search (v: int) requires { in_int32 a.length } requires { sorted a } ensures { 0 <= of_int32 result < a.length /\ a[of_int32 result] = v } raises { Not_found -> forall i:int. 0 <= i < a.length -> a[i] <> v } = try let ref l = cst32 0 in let ref u = sub32 (cst32 a.length) (cst32 1) in while of_int32 l <= of_int32 u do variant { of_int32 u - of_int32 l } invariant { 0 <= of_int32 l /\ of_int32 u < a.length } invariant { forall i:int. 0 <= i < of_int32 l -> a[i] < v } invariant { forall i:int. of_int32 u < i < length a -> v < a[i] } let m = add32 l (div32 (sub32 u l) (cst32 2)) in if a[of_int32 m] < v then l <- add32 m (cst32 1) else if a[of_int32 m] > v then u <- sub32 m (cst32 1) else raise (Break m) done; raise Not_found with Break i -> i end end
