(** {1 MPRI lecture 2-36-1 "Proof of Programs"} *) (** {2 Greatest Common Divisor: Euclid algorithm} *) use int.Int use int.ComputerDivision use number.Gcd (* mathematical definition of GCD already in the standard library *) val ref x: int val ref y: int let gcd () requires { x >= 0 /\ y >= 0 } diverges ensures { result = gcd (old x) (old y) } = label L in while y > 0 do invariant { y >= 0 /\ x >= 0 } invariant { gcd x y = gcd (x at L) (y at L) } let r = mod x y in x <- y; y <- r done; x (* Local Variables: compile-command: "why3 ide gcd_euclid_labels_sol.mlw" End: *)
