(** {1 MPRI lecture 2-36-1 "Proof of Programs"} *) (** {2 Linear search, using a for loop} *) use int.Int use array.Array predicate _TO_BE_COMPLETED constant _VARIANT_TO_BE_COMPLETED:int (* replace all occurrences of _TO_BE_COMPLETED below *) let linear_search (a: array int) (v:int) requires { _TO_BE_COMPLETED } ensures { _TO_BE_COMPLETED } = let ref res = (-1) in for i = 0 to a.length - 1 do invariant { _TO_BE_COMPLETED } let t = a[i] in if t = v then res <- i done; res (* Local Variables: compile-command: "why3 ide lin_search_for.mlw" End: *)
