(** {1 MPRI lecture 2-36-1 "Proof of Programs"} *) (** {2 In-place Linked List Reversal} *) theory ListReverse use export int.Int use export list.List use export list.HdTlNoOpt function append (l1:list 'a) (l2:list 'a) : list 'a = match l1 with | Nil -> l2 | Cons x l -> Cons x (append l l2) end let rec lemma append_nil (l:list 'a) variant { l } ensures { append l Nil = l } = match l with | Nil -> () | Cons _ t -> append_nil t end let rec lemma append_assoc (l1 l2 l3:list 'a) variant { l1 } ensures { append (append l1 l2) l3 = append l1 (append l2 l3) } = match l1 with | Nil -> () | Cons _ t -> append_assoc t l2 l3 end function length (l:list 'a) : int = match l with | Nil -> 0 | Cons _ r -> 1 + length r end let rec lemma length_nonneg (l:list 'a) variant { l } ensures { length l >= 0 } = match l with | Nil -> () | Cons _ t -> length_nonneg t end let rec lemma length_append (l1 l2:list 'a) variant { l1 } ensures { length (append l1 l2) = length l1 + length l2 } = match l1 with | Nil -> () | Cons _ t -> length_append t l2 end function rev (l:list 'a) : list 'a = match l with | Nil -> Nil | Cons x r -> append (rev r) (Cons x Nil) end predicate mem (x:'a) (l:list 'a) = match l with | Nil -> false | Cons y r -> x=y \/ mem x r end predicate disjoint (l1:list 'a) (l2:list 'a) = forall x:'a. not (mem x l1 /\ mem x l2) predicate no_repet (l:list 'a) = match l with | Nil -> true | Cons x r -> not (mem x r) /\ no_repet r end end module InPlaceRev use ListReverse type loc val eq_loc (l1 l2:loc) : bool ensures { result <-> l1=l2 } val constant null:loc function store (f:'a->'b) (i:'a) (v:'b) : 'a -> 'b = fun j -> if i=j then v else f j val acc (ref field: loc -> 'a) (l:loc) : 'a requires { l <> null } reads { field } ensures { result = field l } val upd (ref field: loc -> 'a) (l:loc) (v:'a) : unit requires { l <> null } writes { field } ensures { field = store (old field) l v } predicate list_seg (p:loc) (next: loc -> loc) (l:list loc) (q:loc) = match l with | Nil -> p=q | Cons h t -> p <> null /\ h=p /\ list_seg (next p) next t q end (** Trivial lemma, we need to state it explicitly to help provers prove the post-condition from the loop invariant *) let lemma empty_list (next:loc -> loc) (q:loc) (l: list loc) requires { list_seg null next l q } ensures { l = Nil } = match l with | Nil -> () | Cons _ _ -> absurd end (** Frame lemma for [list_seg] predicate *) let rec lemma list_seg_frame (next1 next2:loc -> loc) (p q r v: loc) (pM:list loc) requires { list_seg p next1 pM r } requires { next2 = store next1 q v } requires { not (mem q pM) } variant { pM } ensures { list_seg p next2 pM r } = match pM with | Nil -> () | Cons h t -> assert { p = h }; list_seg_frame next1 next2 (next1 p) q r v t end (* no repetition property in a null-terminated list, requires auxiliary lemmas: 1) unicity of the model list 2) extraction of a sub-list segment 3) a general lemma 'mem_decomp' on pure lists *) let rec lemma list_seg_functional (next:loc -> loc) (l1 l2:list loc) (p: loc) requires { list_seg p next l1 null } requires { list_seg p next l2 null } variant { l1 } ensures { l1 = l2 } = match l1,l2 with | Nil, Nil -> () | Cons _ r1, Cons _ r2 -> list_seg_functional next r1 r2 (next p) | _ -> absurd end let rec lemma list_seg_sublistl (next:loc -> loc) (l1 l2:list loc) (p q: loc) requires { list_seg p next (append l1 (Cons q l2)) null } variant { l1 } ensures { list_seg q next (Cons q l2) null } = match l1 with | Nil -> () | Cons _ r -> list_seg_sublistl next r l2 (next p) q end let rec ghost mem_decomp (x: 'a) (l: list 'a) : (list 'a, list 'a) requires { mem x l } variant { l } returns { (l1,l2) -> l = append l1 (Cons x l2) } = match l with | Nil -> absurd | Cons h t -> if pure { h = x } then (Nil,t) else let (r1,r2) = mem_decomp x t in (Cons h r1,r2) end let rec lemma list_seg_no_repet (next:loc -> loc) (p: loc) (pM:list loc) requires { list_seg p next pM null } variant { pM } ensures { no_repet pM } = match pM with | Nil -> () | Cons h t -> if mem h t then (* if h occurs in t, we want to prove 'false' *) (* since h is in t, t can be decomposed into l1++h++l2 *) let (l1,l2) = mem_decomp h t in (* then there is a list segment from h to null whose model is h++l2 *) list_seg_sublistl next (Cons h l1) l2 p h; (* but pM is also a path from h to null, so unicity implies pM = h++l2 *) list_seg_functional next pM (Cons h l2) p; (* a contradiction, because of lengths *) assert { length pM > length (Cons h l2) } else list_seg_no_repet next (next p) t end val ref next : loc -> loc let reverse (l:loc) (ghost lM:list loc) : loc requires { list_seg l next lM null } ensures { list_seg result next (rev lM) null } = let ref p = l in let ghost ref pM = lM in let ref r = null in let ghost ref rM = Nil in while not (eq_loc p null) do invariant { list_seg p next pM null } invariant { list_seg r next rM null } invariant { append (rev pM) rM = rev lM } invariant { disjoint rM pM } variant { pM } let n = acc next p in upd next p r; r <- p; p <- n; rM <- Cons (hd pM) rM; pM <- tl pM done; r end (* Local Variables: compile-command: "why3 ide linked_list_rev_sol.mlw" End: *)
