(** {1 MPRI lecture 2-36-1 "Proof of Programs"} *) (** {2 Fast exponentiation} *) predicate _TO_BE_COMPLETED (* replace all occurrences of _TO_BE_COMPLETED below *) use int.Int use int.ComputerDivision use int.Power val ref x : int val ref n : int val ref r : int val ref p : int val ref e : int (** a few helper lemmas *) lemma power_mult : forall x y n:int. n >= 0 -> power (x*y) n = power x n * power y n lemma power_even: forall x:int, n:int. n >= 0 /\ mod n 2 = 0 -> power x n = (power (x * x) (div n 2)) lemma power_odd: forall x:int, n:int. n >= 0 /\ mod n 2 = 1 -> power x n = x * (power (x * x) (div n 2)) (** the power function *) let power_x_n () requires { _TO_BE_COMPLETED } ensures { _TO_BE_COMPLETED } diverges = r <- 1; p <- x; e <- n; while e > 0 do invariant { _TO_BE_COMPLETED } if mod e 2 = 1 then r <- r * p; p <- p * p; e <- div e 2 done let test () diverges = x <- 2; n <- 11; power_x_n(); r (* run test using "why3 execute power_int.mlw Top.test" *)
